Remote Support Software by SimpleHelp
  • USES
    • Remote Support
    • Remote Access
    • Remote Monitoring and Management
    • Remote Presentation
    • Service Provider
  • TIERS
    • Standard
    • Business
    • Enterprise
  • PRICING
    • Pricing
    • Add Sessions or Features
    • Extend Support
  • SUPPORT
    • Downloads
    • Getting Started
    • Guides
    • Support Tickets
  • CONTACT
Remote Management Guide
A guide to all remote management features within SimpleHelp
Remote Management features are built into SimpleHelp, and allow you to manage and support large sets of remote machines without needing to connect to them. Get alerted about changes on the remote machines and easily run tools across multiple machines concurrently.
NOTE: Remote Management features require the SimpleHelp server to have a Management license. You can upgrade your standard SimpleHelp license to allow these features here.
Remote Management Features
Remote Management features are designed to allow you to monitor and manage multiple remote access machines easily from within the SimpleHelp Technician Console. With a Remote Management license you can:
  • Receive alerts about your remote machines.
  • Automatically take action when there is a problem.
  • Run toolbox items across multiple remote access machines concurrently.
Monitoring Alerts
A monitoring alert allows you to monitor key metrics from your remote access machines, and to react to changes in these metrics. For example, an alert might be:
If the available disk space on my server drops below 10% then send me an email.
An alert is always in one of two states:
  1. Triggered - the monitored metrics have changed and are now beyond the trigger threshold
  2. Reset - the metrics have changed and are not beyond the reset threshold.
​In the example above, the monitored metric is Available Disk Space and the alert is monitoring my server. If the free disk space drops below 10% then the alert will enter a Triggered state, and if it increases above 10% the alert will move into a Reset state. The 10% here is the threshold that the metric must pass for the alert to switch state.
Alerts can be configured to take actions when the state switches to triggered or reset. In the above example the alert will email me when the alert triggers.
Alert Threshold Types
SimpleHelp supports a variety of alert types. Alert types are chosen when the alert trigger or reset conditions are set, and are grouped together by category.
Machine Resources
Received alerts to do with resources on a remote machine, like CPU, memory or disk usage.
CPU Usage
Monitor the CPU usage on the remote machine. Receive alerts if it is consistently high.
Memory Usage
Receive alerts if the remote machine is running low on memory.
Disk Usage
Receive alerts if the available disk space on the remote machine is running low.
Disk Health
Receive alerts if one of the drives on the remote machine is about to fail.
Applications
Receive alerts specific to applications running on the remote machine.
AntiVirus Status
Check that the AntiVirus software is running and up to date.
Firewall Status
Receive alerts if the firewall on the remote machine is not running.
Process CPU Usage
Get alerted if a process is using the CPU excessively.
Process Memory Usage
Get alerted if a process is using too much memory.
Process Is Running
Check that a specific application is running on the remote machine.
Files
Received alerts to do with file size, access and modification time.
File Accessible Check
Check if a file exists, can be written to and opened.
File Size Check
Receive an alert if a size of a specific file exceeds your limit.
Last Modified Check
Receive an alert when a file is modified, or if it has not been modified for a long time.
Network
Get alerted about network or server issues.
TCP Port Check
Check whether a TCP port on the remote machine is open.
Website Availability
​Check that a specific website is available from the remote machine.
Website Response Time
​Monitor the response time from a website and get alerts if it is high.
Custom Alerts
Run a tool on a schedule and use it to alert over anything you like
Custom Alert (Scheduled Tool Run)
Custom Alerts allow you to run any of the Tools from your Toolbox on a schedule on the remote machine.  As they are run the return code of the tool run will be checked against whatever you specify to determine if the alert should be triggered or not.
Managing Monitoring Alerts
Monitoring Alerts are contained within the new Alerts tab, in the Technician Console:
Overview Alert Screenshot
The structure of the Alerts tab is very similar to the Access tab. The hierarchy section on the left allows you to easily see what groups of alerts have been created. In the above example the groups include Uptime Alerts and a subgroup Websites:
Hierarchy Screenshot
You can create a new group by pressing the green + button. Created alerts can then be dragged from one group to another.
All created alerts are listed under the Monitoring Alerts main group. If an alert is in a triggered state it is also included in the Triggered Alerts group. If you wish to easily see which alerts are currently triggered you can do so by selecting this main group.
Viewing All Alerts
Alerts are listed in a table structure in the Alerts tab. Alerts in the same alert group are listed together. Each alert is contained on a single line, with additional information about the alert listed to the right.
All Alerts Screenshot
The alerts table conveys a range of information about a particular alert.
  • Active / Inactive: an active alert is one that is currently monitoring services. An inactive alert is dormant. The alerts table shows inactive alerts, like New Alert above, as greyed out.
  • Triggered Machine Count: the Triggered column contains a count of the number of machines that are currently causing this alert to trigger. If this is not zero, the column is shaded yellow to indicate that the alert has triggered.
  • Machines Count: the count of the number of remote access services that this alert is monitoring.
Creating a New Alert
Create  a new alert at any time be pressing the New Alert button in the Alerts tab:
Your new alert will automatically be created and placed in the currently selected group. The alert will also be selected and the alert details panel below will list an overview of the alert's current configuration. If the details panel is not visible make sure that the "I" button to the left of the New Alert button is toggled on.
Configuring an Alert
When an alert is selected the details panel below is populated with specific details about how the alert is configured:
Configure Screenshot
The button bar has two sections:
  1. Alert Configuration: the details of how the alert is configured are presented.
  2. Triggered Machines: list the machines that are currently causing this alert to trigger.
An alert can be made active or inactive by toggling the switch to the right of the button bar. If you wish to delete an alert you can do so by pressing the trash can icon on the far right.
Trigger and Reset Conditions
Trigger and reset conditions dictate under what circumstances the alert will trigger, and subsequently reset. In the Trigger and Reset Conditions details panel, the trigger conditions are listed to the left and the reset conditions are listed to the right.
Alert Trigger Reset Screenshot
Multiple thresholds can be added to a single group, and multiple groups can be created for triggers and resets. SimpleHelp supports two basic threshold groups:
  1. AND Groups -  every threshold within a group must hold for the group to be considered to trigger/reset.
  2. OR Groups -  one threshold within a group must hold for the group to be considered to trigger/reset.
If multiple AND groups are created, then only one of the groups needs to trigger/reset for the alert to trigger/reset. Similarly, if multiple OR groups are created, all of the groups must trigger/reset for the alert to trigger/reset.
You can switch between AND and OR groups by pressing the toggle button in the bottom right.
Trigger and reset conditions must hold for a period of time before the alert state is switched. This time period is configurable, and is specified in minutes allowing you to dictate whether an alert should be concerned with momentary threshold breaches, or whether it should only notify you of long term continuous problems.
When a new Threshold is created a dialog is shown where you can select the threshold type and configure it:
Threshold Screenshot
Select the category of threshold that you are interested in being alerted about (such as Network) and then the specific threshold type. For example, if you choose to be notified about a TCP port you will see the following configuration:
TCP Screenshot
Once the threshold has been configured you have two options which allow you to create either an individual threshold, or a pair of thresholds:
  1. Create One - a single threshold is created.
  2. Create Pair - the threshold you configured is created, and a second threshold is automatically created and added to this alert's trigger / reset conditions. If you chose to add a threshold as a trigger condition, then the second threshold is created as a reset condition.
As an example, a pair of thresholds might be:
  • Trigger if the CPU exceeds 90%.
  • Reset if the CPU falls below 90%.
By using Create Pair, SimpleHelp will create the second threshold for you.  The option to create a pair simplifies trigger and reset conditions in situations where you wish the alert to trigger when it exceeds a limit, and subsequently reset if it falls below the limit. If you require more advanced conditions then it is best to create each threshold individually.
Picking Machines to Alert Over
SimpleHelp alerts can monitor metrics from all your remote access services, or you can specify a subset of services that you wish this alert to apply to. By pressing the Pick Machines button in the alert overview you can specify a set of filters that include or exclude the services you are interested in:
Filter Screenshot
In the example above, this alert will apply to any remote access service with the name SMTP Server. You can see the matched machines for your filter set by pressing the View Machines button at any time.
Trigger and Reset Actions
Trigger and reset actions are actions that the SimpleHelp server will take when an alert switches into a triggered or reset state. If you wish to use SimpleHelp as a monitoring dashboard for your remote access services then you can easily see which alerts are triggered in the alert listing, but actions can be useful if you wish to specify additional steps to take. In the alert overview press Create Trigger Actions or Create Reset Actions to specify actions for trigger or reset events.
SimpleHelp currently supports the following actions:
  • Save To File - write the alert information to file on the SimpleHelp server. This is useful if you wish to keep track of alert state changes.
  • Send An Email - send an email to any recipients of your choice. This is useful if you wish to notify people via email that an alert has triggered. Email actions are fully configurable.
  • Run A Command - run a command on the SimpleHelp server. This allows you to execute a script on the server that may write to file, or populate a database.
  • Send To Website - post the alert information to a website of your choice. Alert information can be posted via a URL encoded parameters, or as a XML chunk.
The actions that can be configured are identical to those documented in the standard technician guide here.
Running Batch Toolboxes
With a Remote Management license your technicians will be able to concurrently execute toolbox items across multiple remote access services. To do this log into the Technician console and select the machines that you wish to execute a tool on. To run a tool press the Use a Toolbox button:
Access Tab Screenshot
A new element will be created in the hierarchy on the left containing each of the selected machines. As the tool is executed on the machine the result in the machine list will be updated to reflect the outcome:
 About    Contact    Legal    Privacy    Cookies
WebEx Alternative - LogMeIn Rescue Alternative - RapidAssist Alternative - Citrix GoToAssist Alternative - Bomgar Alternative - ScreenConnect Alternative -  TeamViewer Alternative - Symantec PCAnywhere Alternative - Altiris Remote Control Alternative - IT Support Software - Remote Control Software - Virtual Classroom Software - Remote Desktop Software - Network Management Software
